Results 1 to 10 of 10
Thread: I found a 68s engine
    I found a 68s engine-UPDATE
    Greetings everyone. Admittedly I'm a newcomer to this forum, but have been active on the bird board for many years with the same SN.
    Long story short, I pulled the engine from my factory 914-6 and learned that it wasn't the original engine, rather an engine from a 1968s. I've included photos below. Knowing the rarity of these engines I'm weighing the option of getting rid of it in hopes reuniting it with a 68s.
    Is there a registry or anything out there that can help try to mate the engine with it's original car in the event I do decide to let go of the engine?
    May 2011
    Chelsea, Québec
    Hi an welcome
    there is a 'lost and found' thread where people may find this info of real interest... kudos for trying to find the right car for it!!!
    http://www.early911sregistry.org/for...d-Found-Thread
    also, you could put the engine number in your thread title...
    Stephen
    Member #1616
    Oct 2008
    Burford, ON, Canada
    serial 4080519
    type 901-02
    build 11391
    I believe there is one fellow here who has been successful deriving the VIN from the engine #. But this is a nice aluminum case, and should be worth a fair bit.
    Personal email sent.
    serial 4080519
    type 901-02
    build 11391
    Thanks for recording these details. It would be cool if we could track this down to the vin.
    Oct 2008
    Burford, ON, Canada
    Ben, don't be shy about that honey of a 914/6 that you have. Perhaps you could email me more info about it for my database.
    Dave
    Oct 2008
    Burford, ON, Canada
    would be close to these coupes
    11800440 4080522
    11800468 4080521
    or a Targa near
    118501xx
    I firmly believe it came from coupe 1180044x - to 1180045x. That narrrows it down
    ~J~
    air cooled only
    I do plan on pulling the valve covers to see if I can determine if the cams are original and will put a boroscope into the cylinders to see if the pistons look correct.
    I pulled the valve covers to try to see the part numbers on the cams. Here is what I found:
    Left cam: 901.105.109.01
    Right Side: 901.105.110.01
    Based on what I've found the cams are 1965 solexes?
    I tried to check the piston top shape to determine type but I couldn't nail down a definitive shape.
    How does this I for action impact the valuation?
