Results 1 to 7 of 7
Thread: SWB Inner Sill Silencer Question
    I believe early cars like mine have a tube silencer and later cars have something differant
    After removing the inner and outer Sills my silence has holes in it.
    Is it best to repair or replace?
    Is it easy to remove and reinstall (to check the side I can't see)?
    Is the part available OEM/after market?
    Any help would be much Appreciated
    Any alternatives?
    And do they slide off once you super heat the brassed parts?
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    here is the answer to your pm....the stupid guys in the acid dip shop did cut that hole....
    But one the car has been dipped I assume the wool stoney bits get wet and then become no good!!
    Has anybody used exhaust baffles etc??
    Sep 2009
    COPENHAGEN, DENMARK
    these tubes will be available pretty soon
    I am at the final stage with these
    only difference is, I will o not use the stone wool material inside, but a foam tube
    otherwise they will be exact as original ones, should be ready for 1st of august
    pics to follow asap
    Marek
    Still required urgently
    Any help please
