FS: ST-classic Parts
refer website for photos
- Twin coil weld on mounts $55US shipped - IN STOCK
- ST / RSR weld on strut brace brackets ( pair) $120US shipped (to usa) IN STOCK
- Cibie hood light backing plates $55US pair shipped IN STOCK
- Early Parcel tray harness mounts (weld in ) $215US (pair) shipped IN STOCK
- LWT recaro seat mounting brackets STD fit for porsche recaro lwt race bucket seats , have been fitted to after market versions also without issue-----$210 shipped - IN STOCK
- Heater duct cover plates - made from spun ali sheet , we made these to be a straight bolt on to replace your flapper boxes when using headers and keeping the dirt and moisture out of the chassis , super light weight the kit ( 2 x covers , gaskets and nuts ) ------$115 Shipped now in stock
- R/ST/RSR - Y harness for the spare tyre - now available in brown/natural and black / black in 65/85/100 and 110ltr tank sizes - 65/85 $110US 100 / 110 ltr $135US shipped ( all leather options also available )
- RSR weld on strut brace brackets - $115US shipped
- R / ST / RSR - Leather door stays Reproduction of the straps often seen in the 911R as a means to hold the door from opening to far . Idea for the ultimate light weight option Made from quality English leather kit inc's straps ready to screw on and 4 metal porsche clamps .
$95us per pair shipped (brown or black )
- original bracket part 911.201.313.00 for installing the plastic rs 85ltr tank . Ready now
NEW stuff
Rear skid plate - ali plate 6mm with all stainless brackets and fittings. inc nylon blocks placed in spots to allow better pressure spread if hit straight bolt on approx weight 3.85kg's. LWB 69-73 ( will check on a swb soon ) drain holes in place for engine (offset) and gear box.
shipped to your door by COURIER (only option) $420US (Usa only other countries poa) made to order item
Front pan LWB 69-73 , will fit any std tank (metal or plastic ) straight bolt on at rear , boltholes needed to be drilled for the front . lwt ali with ali brackets .bead roller ribs installed to stop flex .approx weight 1.95kgs
shipped to your door by COURIER $346US (USA only , other countries Poa) - made to order
Due soon - Roll bar crows feet approx 2 weeks
PM me here please
