Thread: Help with Clutch
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    Help with Clutch
    So I was pulling into my garage today, and when I pushed in the clutch pedal, I heard and felt a pop. Needless to say, now my clutch will not engage. I lifted the car, and looked at what was going on under there. Cable and ends are fine. I removed the clutch cable, and tried to push the fork backwards. It is just frozen, and will not move back
    I am thinking my throwout bearing failed somehow. Any thing else I should consider.
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    When you say the clutch will not engage you mean the pressure plate is always clamping the clutch together, right?
    The type 911 gearbox from 1970 and 1971 has a reputation for pulling the fork pivot out of the transaxle case as I understand it, though I have not had that happen.
    Dec 2007
    Spartanburg SC
    I have not dropped the engine and looked things over yet. So I don;t know. Right now, all I can say is the fork can not be pulled backwards. It sounds like what you are suggesting is quite likely. Will have to see what I got when I get in there.
