Thread: Koni Front Strut Lower Ball Joint Color question
    Nov 2011
    Bluffton, SC
    I have Koni front Struts on several 65 911 & 912 cars. Should the lower Ball Joint (assembly with arm that is mounted into the A Arm and the tie rod arm) be Koni Orange or Black???
    Thank you for your help!
    Charles C
    Hi Charles,
    It should be black.
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Nov 2011
    Bluffton, SC
    Brad,
    Thank you!
