Thread: Adjust glove box door SWB
    The glove box door is high on the left side and a bit low on the right side. How do you adjust this? Are fittings behind the knee pad?
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Member 66DC's Avatar
    Apr 2011
    Washington DC
    Check the glove box door alignment first. If it looks straight, then it could be the aluminum/basketweave trim was glued on crooked.
    1966 911 coupe, Granite Green
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Undo the knee pad, up behind the ledge (I'm guessing 8 nuts on SWB)
    Once you get it off, there should be 2 screws that hold the glovebox door that have a small amount of adjustment.
    Tony
