Thread: Heater unit for 69t
    Heater unit for 69t
    Hello,
    Could someone tell me what is installed here and where else it connects to on the other end. Looks like it's missing? The car is a 69t LWB.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    It's a 4 pin plug, similar to the style that's fitted to the gas/fuel tank sender.
    It's more than likely tucked up behind the blower somewhere.
    It should be in your main wiring loom.
    The wiring originates from blower controls (3 levers) on your dash.
    Tony
    Found it thanks Tony.
    I have missing a small piece of pipe which fits with a rubber seal just above the smugglers box.
    Do you know if there are spares available?
    Thanks Lee
    Nov 2004
    Gold Coast.
    I was running a suitably sized piece of rubber hose.
    But it would appear that Marek is making these.
    http://www.early911sregistry.org/for...lower-Assembly
    Tony
