Thread: Hardi fuel pump specs -- From SWB. Will this work with '71 2.2?
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    This Hardi fuel pump was used to fuel a 2.0 in my '66. I'm installing a '71 T engine with Zeniths. I can't find specs on this pump. Only ID on pump is Hardi DBGM and 2879. Does anyone know the specs on this pump -- type number, flow rate, pressure? I'm wondering if it will work with my new engine.
    Joe
Size:  70.1 KBName:  hardi 2.jpg
Size:  57.6 KBName:  hardi 2.jpg
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    Yes it should, the '71 T was the last of the carbureted 911's. The Hardi just doesn't have all the fuel return connections. I'm assuming the flow rate and pressure are fine for your Zeniths, I don't have the specs.
    Here's some '71 pump info
    http://www.early911sregistry.org/for...ight=fuel+pump
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    My Hardi puts out 3.5 PSI.
    As an addition to stock I have an inline fuel filter fitted before the carbs.
    Tony
