Results 1 to 2 of 2
Thread: Restoring heat exchangers
    What is the proper method of restoring the heat exchangers for an early ( 1969) 911S? They are currently being chemically cleaned out by CAPS powder coating in Fresno County, CA awaiting instructions for the correct finishing. The shop does have a number of high temperature finishes, if they are best to be coated with a ceramic type coating.
    Thanks for the advice, in advance.
    Jerry G
    "Confidence is the feeling you
    have before you fully understand
    the situation."
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    I would go with a ceramic powder (high temp) if you're restoring rather then replacing.
    Tony
