Results 1 to 2 of 2
Thread: MFI Fuel Pump - Return Line T Piece
    Dec 2011
    Sydney Australia
    I am about to fit the correct Bosch MFI fuel pump to my car to replace the aftermarket one previously fitted, which only has an inlet and outlet - no return.
    Is there anything special about the T piece (one way valve e.t.c) that I need to fit to connect the MFI injection pump return line and fuel pump return to the return line to the tank, or will an off the shelf brass T piece do the job?
    Rob
    Nothing special about the part.
