Thread: Are the early S dash aluminum edge pieces being reproduced?
    Nov 2006
    S. F. Bay Area
    The narrow trim pieces above and below the basket weave….I thought I read here that they were being redone, I searched, but can't find it.
    I could be way off.
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    Thanks, but I'm looking for the aluminum trim pieces that surround the basket weave. Neither of these sources has the correct pieces as fitted to a '67. But….thanks.
    Brian
    S Reg #1032
    Member Ken F's Avatar
    Sep 2010
    Central Florida
    Brian,
    I'm not sure but the dash edge may be the same extrusion as the J-trim that CarmelSkip is reproducing.
    It takes 4 pieces cut to fit on top and 2 pieces on the top edge of the knee pad.
    Mine was all there and just needed cleaning up.
    Nov 2006
    S. F. Bay Area
    You're right, and I just ordered the piece I need for the lower dash pad…the long one, from him. I hope I get it straighter this time. Thanks
    Brian
    S Reg #1032
