Thread: Fuel tank coat stripping question
    What is the best way to strip the coating off the fuel tank. Anyone know of a solution that will cut through this stuff?
    Please help I wore out my scraper.
    Jun 2009
    West Hills, CA
    Paint remover.
    Small grinder.
    Espo
    75 911 SCRS
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    I use all of these methods for undercoating. In no particular order :
    MAPP gas and a scraper
    knotted wire wheel on a grinder
    razor scraper ( dull fresh blades a bit. when they're brand new the blade will dig into the metal and make it a PITA )
    Dynazip stripping wheel ( requires a special tool ) http://www.toolking.com/dynabrade-pr...-dynazip-tool/
    I've heard rumours of dry ice being used, but have no personal experience with it
    I normally use the MAPP gas and scraper to get the bulk, then go back with the Dynazip. FWIW, The gas and scraper is the least messy, and the least noisy.
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    +1 on a small propane torch and scraper. Messy job but gets the undercoating off fast.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    a good heat gun works well too.
    Mark..
    Thanks folk, heat and elbow, I am getting close
