Thread: Engine #Pos 10953?
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Engine #Pos 10953?
    bought a 2liter 911 engine(casted in 66) that has a strange serial# have a look at the pic...and it does not have the engine type stamped in.
    is this a replacement engine??
    thanks for your help.
    franz
    "KD" or "AT" for factory replacement is more usual. Not familiar with this.
    Good luck.
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by sithot View Post
    Good luck.
    yes thats what i also have seen several times....
    any other ideas??
    Oct 2008
    Burford, ON, Canada
    I'm sure that would be a replacement case. As to the stamping you find, it must be something that a local shop would have done. If you could trace the history of the case, then it might make sense.
    The numbers seems to be made by different stamps i.e. they look different and the size does look different.
