Thread: Switch above ignition...
    May 2011
    Chelsea, Québec
    I found this switch on my car, and have no idea what it was used for... there were no fog lamps, rear wiper, etc fitted to the car
    The switch looks aftermarket too, so any ideas or information would be great!
    Cheers
    Stephen
    BTW: the shiny key tag was the POs, not mine and I didn't get round to changing it yet!!!
    Member #1616
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    What year is the car. Do you have a webasto heater. Looks more like a PO self wiring though.
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    Follow the wires from the switch and see where they go. People can put switches in for all kinds of reasons.
    Oct 2010
    South Carolina
    That's the flux capacitor override switch. Don't touch it or 1.2 gigawatts could be applied to the generator! Ha! Aftermarket switch installed by a PO. Nonstandard. Could be used to actuate anything from fog lights to alarm. If the wires still there see if you can trace them. Otherwise remove it and patch the hole.
