Results 1 to 10 of 13
Thread: how to polish the plastic lights?
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I have nice crackless rearlights and front indicators and feel they deserve to be scratchless and polished.
    Any tips and tricks to do this without wrecking them and leaving the surface tranished forever?
    Which gel and equipment to use, are ther several steps to take account of?
    txs jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Jul 2011
    Chicago Area
    Just use 3M scratch remover available at most auto Parts stores. Just use a smooth towel and hand rub the lenses, for deeper scratches first use 400, then 1000, then 1500 grit sand paper followed by the 3m scratch remover.
    Mike Fitton # 2071
    2018 911S Carrera White
    Jan 2011
    Sunny Southern France
    toothpaste should also do the trick!
    Elbow grease unfortunatelly can't be bought to your local store...
    Olivier
    Meguiars plastic polish
    This stuff is the s**t. Designed for paint but I use it on almost everything including lenses.
    http://www.amazon.com/Meguiars-G1030...ords=scratch+x
    May 2014
    Netherlands
    Txs guys, leaves me to go to the shop and just start I guess.
    Cheers.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Registry Member #2679 friggens's Avatar
    Jul 2013
    Albuquerque, NM
    Quote Originally Posted by Olivier View Post
    Followed up with some corn starch
    May 2014
    Netherlands
    How to apply that? I guess it comes in powderform and needs to be diluted to a paste? Then rub onto the surface until it dries?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Dec 2010
    Tulsa
    We used it dry back in the day to buff lacquer
    Simichrome if the toothpaste does not work. You can dilute it or go full strength. It works wonders on plastic.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
