Thread: std dist. to rsr dist . ?
    Sep 2008
    Auckland , New Zealand
    http://forums.pelicanparts.com/porsc...r-replica.html
    Is it really as easy as this advises ? just a plate and cap/rotor
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Jan 2003
    UK
    The early repro twin-plug distributors still used an original Bosch twin-plug cap & rotor - both of which were very expensive.
    The main reason that various people (eg Aaron Burns) developed the currently-available twin-plug distributors was to be able to utilise a cheap/readily-available (but very similar looking) 12-plug Marelli distributor cap.
    The rotors are usually custom-made (or replaced by a magnetic trigger).
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Feb 2011
    Northern VA
    There are versions of this that are much better than others, both using the MM jag cap and a custom rotor-- the original bosch rsr caps are $500+? Rotors $???
    I have one cheap one that clamps on to the distributor... Similar but larger than the one shown, but more substantial. My experience is that it has a slight miss at 6800 rpm or so and then smooths out. I think it's because the shaft isn't supported by a bearing when swinging the big rotor?
    Replaced it with one of Aaron Burnhams units and it disappeared. Have since swapped back and forth. His are also made from standard bosch distributors, but use a very nice machined bolt on head instead of a sleeve that clamps on. Accurate, very pretty. They are works of art and worth the price.
    I have an old andial adaptor. If you can find a cap and rotor. I still think they are inferior to other units out there.
    Senior Member Fubawu's Avatar
    May 2013
    can you post pictures of these set ups. It would be great for reference.
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    I'm subscribed to this post!!!!
    Feb 2011
    Northern VA
    Will post some pics when I get off vaca next week
