Thread: Engine Trim bolts
    Senior Member drwhosc's Avatar
    Dec 2007
    Spartanburg SC
    Engine Trim bolts
    I need a couple of the screws that go on the engine shroud to the fan housing. I think they have a broad flat head with a slot.
    71 911E RS Clone (Analog)
    88 928 S4 (V8 Trans Axle)
    99 996 (Daily Beater)
    Early S Registry # 1278
    I can't think of anyplace on a 911 engine that uses slotted screws, if I'm reading your location correctly those would be 6 X 1.00 X 12 yellow hex head bolts. The last time slotted screws were used were the 912 engines.
    Dec 2007
    Spartanburg SC
    Cool, good to know, Looks like I was going after the wrong thing. I looked around in my bag of nuts and bolts, and think I found what I need. just a bit dirty. Not going for concours, but like to keep things complete.
