Results 1 to 10 of 13
Thread: you find the damnedest things in your fender !
    I thought I would share these pictures with you as I take on the task of restoring 69 911 E number 824. While in the disassembly process today, I uncovered this fairly elaborate evap tank in the drivers rear fender well. I've never seen anything like it before, and can't imagine why it was needed, but someone went through a lot of trouble to mount it, and plumb it. It even has a little drain plug. It takes the evap oil from the oil tank on the passangers side, and runs lines along the back of the tail light panel to this catch tank. It's pretty large, about the size of a 2 liter soda bottle. I'm not sure if this was a kit back in the day, but thought I would post it for posterity
    1969 911 E #824
    Are you sure it is not an onboard beer keg?
    When the Boxster came out it had a special recess in the front trunk for a pony keg.
    you may be correct...It may indeed be a pony keg of Spaten. I will try to tap it tomorrow!!
    1969 911 E #824
    Sep 2008
    Auckland , New Zealand
    james bond jet fuel tank adder
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Dec 2003
    West Los Angeles
    World's largest fuel filter?
    techweenie.com
    My parts fetcher: 2014 Tesla S | Currently building: 73 RSR tribute and 69 RS tribute
    Nitro tank or moonshine car
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Apr 2011
    N.Calif., south of SF
    Some sort of emissions retrofit?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Dec 2009
    Copenhagen, Denmark
    I would say it's Nos. Nitrous baby.
    James Hurst #1638
    R Gruppe #514
    'outlet'? . . .
    . . . did anyone ever figure-out what this kooky thing actually was? . . .
    . . . + is this Faktory?
    It is for sure not factory. It ended up being a diesel oil filter adapted to give larger oil capacity and more filtration. My guess is a savvy mechanic sold this at great expense to a previous owner. On a side note the chassis is almost out of paint and I will be re-assembling it over the next year or two....
    1969 911 E #824
