Thread: Price check on an unstamped 7R case?
    Member Boeder's Avatar
    Apr 2003
    Minnetonka, MN
    I have an unstamped factory replacement 7R case. Casting number 901.101.102.7R
    Linebored, shuffle pinned, boat tailed, case savers, set up for a 930 oil pump - all claimed to have been done by German Precision and Ollie's according to the previous owner.
    Unfortunately, it has a crack in one of the webbings for the journals - see attached photo
    It's for sale but I have no idea of its value.
    Can anyone help me out with that?
    I have more photos that can be sent directly, if someone is interested in seeing them.
    Bruce
    Dec 2003
    West Los Angeles
    Have you asked a machine shop if/how they would repair it? Generally, an unstamped 7R is fairly valuable to someone missing their car's original engine, as an unstamped case is better than an incorrect # engine. The machine work, if verifiable, adds value, but any buyer is likely to re line bore, as it's just prudent, and checking takes 80% of the effort of bore cleanup.
    I don't know enough about welding magnesium, but would think the case would have a potential failure point even if repaired. Seems an odd spot for a crack...
    Good luck.
    techweenie.com
    My parts fetcher: 2014 Tesla S | Currently building: 73 RSR tribute and 69 RS tribute
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Eminence Gris View Post
    Actually very common on race motors.
    I've run sandcast aluminum cases this way for a hundred hours but would be a little paranoid about a mag one.
    Jan 2011
    Sunny Southern France
    http://www.locknstitch.com/metal_stitching.htm
    But this area might be toot hin for that...
    From a mechanical point of view, it is surprising to see such a crack in this polished area. That gives an idea of the stress level!
