1975 Euro Carrera RS type 911/83 Engine Case
Ollie's just complete the following work:
Align bore back to standard ( milled case halves)
Deep inserts at #3
3 inserts at trans mount
Clean oil squirters
R&R oil plugs and hot tank
Tumble case for new appearance
Oil bypass mod and kit
Rebuild 6 connecting rods
Shims provided to maintain stock geometry
Also have chain boxes, cam towers, flywheel, mount, crankshaft etc.
No cams, heads, pistons, MFI
Engine has previously installed head bolt inserts
$15.5K for all, a bit less for just the case
Rick near Reno, Nevada Acme3r@gmail.com
