Results 1 to 9 of 9
Thread: Boge strut , need advice on how to remove insert??
    Senior Member Fubawu's Avatar
    Hi
    I was hoping someone could help me in regards to removing the front inserts on my Boge
    struts. I have unbolted it and from what I have read and could remember the insert should simply
    pull out from the top. Well I have pulled twisted pipe renched ,pryed screamed to no avail!!
    There is no locking pin for Bilsteins that I can see but it does feellocked into place!
    I must be missing something any advice would be a big help.
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Senior Member Per Schroeder's Avatar
    Mar 2013
    Avon Lake, Ohio
    That gland nut unscrews---use a gigantic pair of Channel Locks or *very* large pipe wrench.
    Per Schroeder
    I tried cant seem to budget it! I must need a little more power....maybe after dinner
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    I always shove the piston back up unto the fender mount, and then let the steering go all the way in the direction I'm trying to loosen. This keeps the strut from flopping around as you're applying all that grunt to loosen.
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    A little heat? Mine came out pretty easily with a decent long pipe wrench
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Jr Member that looks Sr DanPez's Avatar
    Aug 2014
    Hudson, Quebec
    The outer skin is thin metal so if you placed it on a vice chances are its warped to an oval shape and making the pulling out even harder.
    Try pulling it out while twisting the insert to reshape the casing.
    Daniel
    73 Sporto 911T-V RoW
    But he first has to unscrew the retaining nut.
    Apr 2012
    Simi Valley Ca
    Careful with the heat, those things are filled with oil.
    Bob B
    Aug 2010
    If it has the 2 holes on the top like a pair of boges struts I just did, I used one of these I bought from Granger.
    http://www.grainger.com/product/1APC...cm_vc=IDPBVZ12
