Thread: Weber Rebuild Question. Accelerator Pump Cover
    Hi. I'm rebuilding my Webers. Attached is a picture of my accelerator pump cover. It looks to me like the sealing face is warped. Is it supposed to be like this? If not, can I have it machined flat or will that change the amount the actuator pushes into the diaphragm. Thank you in advance.
    Dec 2008
    Woodland Hills, CA
    Pretty common. You can machine it or Paul at Performance Oriented can exchange ready to go covers for you.
    http://www.performanceoriented.com/
    Feb 2014
    Austin, TX
    FYI, PMO sells thicker replacements in aluminum vs. the thinner pot metal used by Weber if you decide to replace them. I purchased the PMOs recently, and posted some pictures on Pelican:
    http://forums.pelicanparts.com/porsc...r-plating.html
    Also, if you're purchasing new pump diaphragms from PMO, you may find this thread helpful:
    http://forums.pelicanparts.com/porsc...ator-pump.html
    I ended up cutting off about 1-2mm from the hex heads on the new diaphragms.
    '73 RoW 911T (project)
    '77 911S
    Early911SReg #2945
    Put a piece of sandpaper on a piece of plate glass and sand it flat. We do this all the time. We do it in the parts cleaner so there is a steady flow of fluid flush out the grit.
    Thank you everyone. I will take care of this tomorrow. I do appreciate it.
    Don
