Thread: Exhasut leak causing backfiring
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    Oh collectve wisdom....
    Over the winter, I had the engine (69 911E motor with Webers) out of my car (69 912). I sent my Webers to Kurt at Partsklassic for a beautiful rebuild. Bought new Dansk heat exchangers. Re-installed the carbs and manifolds with all new gaskets. Installed the heat exchangers with all new head studs (well, 11/12 - couldn't get one to budge), new hardware, new gaskets.
    However despite all that, I am plagued still by my demon - a deceleration backfire loud enough to send Suge Knight running (too soon?) and I'm sure set my neigbours cursing (of course, I live down a big hill, so I'm poppin and bangin the whole way down the hill). I know I likely have a pinhole exhaust leak somewhere. I suspect that one of the flanges on my exhaust port is a little wonky. It doesn't backfire constantly on decel, but pops a bit and lets out an occasional BANG!
    Before I commit an atrocity like gooping up the gaskets with form-a-gasket in hopes of sealing the leak, is there any good methods for trying to figure out where the leak is? I'vetried laying under the car wih a chunk of tubing stuck in my ear and listening, but to no avail (aside from minor heat-stroke due to being that close to the heat exchangers).
    I want to get on with the final tuning of the carbs, but this backfire is the bane of my existence. I had such high hopes that all this work would solve the problem, so you can imagine my frustration.
    Keith (slightly deaf in left ear now)
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Nov 2006
    S. F. Bay Area
    Perhaps try lying (hoist?) under the running motor with a spray bottle of slightly soapy water. Any exhaust leak will reveal itself with bubbles.
    Brian
    S Reg #1032
    Dec 2008
    Woodland Hills, CA
    With misadjusted carbs, an exhaust leak may not be the culprit. Do you actually hear the exhaust leak?
    Port Macquarie, Australia
    I spray a little Aerostart (ether) around the manifolds, one at a time - you soon hear a change in revs if there is an induction leak. Doing the same around the exhaust and flanges will probably illicit a pop when you're close to the right spot.
    John Forcier
    EarlyS #1987
    Restoration Saga
