Results 1 to 10 of 15
Thread: Alternator wiring questions 71 911T
    Junior Member
    Aug 2014
    South Florida
    Cool Alternator wiring questions 71 911T
    In wiring the Motorola alternator...I am in the dark on this one....I have run into conflicting documentation. I did not take the engine apart and no pictures or supporting documentation to assist. So...want to assemble on the side of caution and insure that I make the appropriate connections to the alternator. I have the following wires and colors and connections as indicated in the Haynes manual.
    B+ 1 RED large wire no problem this is larger red wire
    DF 2 Black no problem this is a spade connector
    D_ 3 Brown wire no issue
    D+61 RED I have a blue wire...and not clear exactly where it connects....does anyone have a picture or diagram
    Also not clear as to where to connect the alternator ground wire on alternator and on the case... any pictures or clarification greatly appreciated.
    The terminals are marked on the alternator.
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    Name:  IMG_8519 (Medium).jpg
    And run a ground wire from the fan housing/alternator mounting nut to the engine case.
    Thomas
    1973 911S Targa
    Junior Member
    Aug 2014
    South Florida
    As I think about it (slept on it)...I believe that the brown wire is the ground and the alternator terminal for ground is labelled D-. Is that correct...?
    Jan 2011
    DFW TX
    Yes. The picture above shows it clearly. There should also be a braided ground strap from the housing to the engine case.
    Aug 2011
    New York
    Here is another picture showing the alternator connections. As for the ground strap to the engine, that was only needed on later alternators with the internal regulator. Early cars don't need it.
    E Sully
    1973.5 911T
    Hate to disagree here Mr. Sully, but I believe they all got the ground strap irregardless. I always put one on, can't hurt to insure good grounds.
    Having recently done this on my 73 with Sev/Marchal, there are 2 ground straps, one at the rear braided and one of the rear fan air vanes going to the fan housing.
    Aug 2011
    New York
    Edmayo is correct.
    E Sully
    1973.5 911T
    +1 for Ed. I've rebuilt so many engines I can't keep track, all early engines had braided ground strap from bottom stud of alternator, thru fan housing, connected to one of the top engine case studs. Gled
