Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Alternator wiring questions 71 911T
  1. #11
    Junior Member
    Aug 2014
    South Florida
    I agree with a ground strap...but the only problem is that I hesitate to remove the case nut to attach the ground strap to the case. The case is all together and torqued...would you think it would compromise the integrity of the case seal? After all there is a brown ground wire attached to the alternator that goes to earth somewhere.
  2. #12
    The case won't even know you did it, in fact one stud is always a few millimeters longer just to accommodate the extra thickness of the strap. Sounds like someone didn't put a strap on when it was last assembled?
  3. #13
    The reason for the thick strap is not an electrical ground, although it provides that function, as you say correctly there are other brown ground wires.
    The reason for the thick strap is a HEAT SINK.
  4. #14
    Aug 2011
    New York
    That is interesting. Mind if I ask where you heard this? The original ground wire on the '86 engine with internal VR I had was an insulated brown wire.
    E Sully
    1973.5 911T
  5. #15
    Aug 2011
    New York
    In case you want to go original, I looked it up in tha PET. The part number is 901 612 110 00 Ground Strap Engine Generator
    E Sully
    1973.5 911T
