Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: gearbox 8/65 question
  1. #11
    '65 912 451326 has trans 221466 (902/1); delivered August '65 at factory in US spec.
    Frank
  2. #12
    my chart for this trans
    902/1 from 220001 to 221721 912 ending 1965 07 26
    902/1 from 221722 to at least 232398 911 & 912 1966
    902/1 from 234001 to 238942 912 1967 5 speed
    902/1 from 130001 to 131571 911 1967 5 speed
    902/1 from 3280001 to 3281317 911 1968 5 speed
    So only in 1966 was this trans shared between the 911 & 912 from the same serial range, otherwise each model had it's own serial range.
    Dave's chart is probably the best guideline for this transmission.
    There seems to be no factory chart with '66 transmission serial numbers.
    Jon B.
  3. #13
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by Frank Barrett View Post
    do you have the date code from this one Frank?
    Oh, and the case casting # also please; trying to figure out the .02 to .0R in that serial range. A photo of them together would be helpful; they are near the diff side cover.
  4. #14
    Photo of a transmission casting date
    902/1
    222518
    10/65
    901.301.101.02
    Number 10 indicates the week, not month, the housing was cast in 1965.
    Jon B.
    Vista, CA
  5. #15
    Oct 2008
    Burford, ON, Canada
    the progression of casting dates is a bit odd, but I often see these in reverse order; sort of first in last out inventory practice.
    222024 20/65
    222127 14/65
    222518 10/65
    222567 25/65
    222868 31/65
  6. #16
    Probably not intended practice, it just occurred that way on occasion.
    The dates were important for quality control, if casting flaws were discovered, but otherwise didn't matter to Porsche if housings were used out of date sequence.
    Jim should pull down all his 901 housings and photograph them for you ;-)
    Jon B.
  7. #17
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Great info. Thanks!
    Do you also have the period chart for the 901/0 gearboxes for the 911 in 1965?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
