Results 1 to 7 of 7
Thread: hose egine-to-oil tank routing, is this correct? 1970, driver's side hose
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    Can someone take a quick look at your car and let me know if this is correct? It's the hose that goes from the driver's side of the engine to the oil tank. Does it go between the starter and the transaxle (as I have it), over the starter, or simply under the engine?
    Thanks.
    Joe
    Name:  hose routing.jpg
    Dec 2008
    Woodland Hills, CA
    My 68 routes over the starter.
    There were two small brackets that held adel clamps, one bolted to the side cover of the trans and one at the top starter bolt. The adel clamps held the oil hose over the top of the starter. Gled
    Nov 2009
    DC/Montana
    Thanks for your help. I'll put it over the starter.
    Joe
    My '70 routes over the bellhousing & starter.
    Cheers
    JB
    Aug 2009
    SF Bay Area
    That is completely wrong. It isn't even close to a 70 transmission. What's the deal with the picture?
    Nov 2009
    DC/Montana
    Good point Jim. 1970 engine mated to a 1966 transmission.
