Results 1 to 1 of 1
Thread: Help with my sun visors
    This should be easy, but I'm missing something. Perhaps someone can, once again, bail me out...the sunvisor on my car (and many others) has two screws on the corner mounting bracket and then a shaft to which the visor is mounted with a set screw. That shaft has a groove near it's end and an elevation/bump near the mounting point. I can't figure out how the groove, protrusion, and set screw all fit together. I got the visor mounted but it keeps falling down from it's high point folded against the headliner. What am I doing wrong here. The visor's plastic mounting point broke off and that's the reason for the R&R. Here are some pictures that might help.c
