Results 1 to 10 of 16
Thread: FS: U-shaped clip blaupunkt radio
    FS: a U-shaped clip for blaupunkt radio, asking $75
    Senior Member Sun888's Avatar
    Feb 2014
    Switzerland
    I'll take it. Will send PM in a minute...
    '70 E Coupe Pastel Blue
    '73 S Targa Gold Metallic
    Registry #2890
    Feb 2010
    San Francisco, CA
    FWIW, I believe that is the clip that attaches to the firewall of the car, not the radio itself. Shorter radios need the "male" half still. Early radios will go directly into this clip.
    Just wanted to help inform people looking for the clips.
    E911SR & RGRUPPE
    '73 S Coupe #306
    I'm also looking for one of these if the buyer changes his mind.
    Sep 2006
    San Francisco
    This one appears to be missing the tabs that lock the bracket in place. It can still work with bolts, but buyer should know that isn't the way it was intended. The tabs are rather fragile so shearing them off is not uncommon. Ask me how I know...
    Also, Automobile Atlanta sells a 914 Blaupunkt radio installation kit that includes a U-shaped bracket as well as the speaker cable with Blaupunkt connector. The u-shaped bracket looks virtually identical. The whole kit is only $29.50.
    http://www.autoatlanta.com/Porsche-914-Radio-srch.html
    Jeff Jensen
    Feb 2014
    Switzerland
    Hi Enzo05
    Is Jeff correct and the bracket is damaged/something missing?
    Marcus
    (edit: typo)
    Registry #2890
    I do not know, apparently yes
    Feb 2014
    Switzerland
    Hm ... in that case I'd like to back out. I need it to be a 100% intact.
    Registry #2890
    LiveFromNY you're next in line, are you still interested?
    Senior Member mohrgan's Avatar
    May 2011
    Upstate NY
    Jeff is correct. The two tabs that hold the bracket in place are missing. It could still be used with bolts or rivets but it would not be 100% correct.
    -Chris Mohr
    S Registry #1978
