Thread: FS: New JE Pistons, 85mm, ceramic coated
    SOLD
    Brand new JE 85mm pistons. Project changed directions and never got around to using them.
    $695 + Shipping + PayPal
    For $100 extra, I will also throw in a set of Mahle 84mm cylinders that I believe can be bored to 85mm. One cylinder is pretty rusty, so is questionable.
    Pins and keepers are included, of course.
    All sharp edges on the pistons were relieved and polished, then the pistons were ceramic coated. I noticed some runs on the skirts, so smoothed the skirts with some Scotch-Brite pad to ensure smooth entry into the barrels. As a result, consider the crowns and ring lands coated, although much of the skirt area is still fully coated.
    9.0:1 CR on 66.0mm crank
    9.5:1 CR on 70.4mm crank
    Perfect for a:
    • 2.0 Normale, T or E
    • 2.2 T or E
    • 2.4 T, E or S
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Quote Originally Posted by kenikh View Post
    Perfect for a:
    • 2.2 T or E
    • 2.4 T, E or S
    Which is the stock crank spec for a '72 2.4 T?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    That would be the 70.4mm, which results in a 9.5:1 CR.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenik, your mailbox is full.
    Sent you an email with all the details
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hi ,
    sent you a pm,
    Charlie
