Thread: 73 S - need help identifying where to mount air cleaner piece
    I can't identify where to mount this pipe through its mounting tab in the engine bay. It is an associated component of the air cleaner where a vacuum/fuel hose connects between the small pipe on it and at the rear center/bottom of the air cleaner. Thank you!
    It is the drain pipe for the air filter housing, mine is in gold zink by the engine stand head.
    I did mine in black......... here showing the rubber drain nipple
    Thank you both...sure wish I had remembered this before installing the engine....hopefully it can still be put in
    It can if you cant get a wrench on it back there you can use a vw cheese head screw,
