Thread: Poor man's alignment question
    Nov 2006
    S. F. Bay Area
    Just want it to go sorta straight on way to the alignment shop (soon hopefully).
    The 2 eccentric bolts in the rear spring plate…..which one is camber, which is toe??
    No guesses, please. Thanks
    Brian
    S Reg #1032
    forward ones are toe and rear are camber.
    Nov 2006
    S. F. Bay Area
    Thanks mate.
    Brian
    S Reg #1032
    Jan 2011
    DFW TX
    Its pretty obvious when you start fiddling with it. Rough in the toe first, then set the camber. Then recheck toe. Etc. You are mostly making sure nothing is going to rub. I find a laser pointer and an iphone clinometer app very useful when doing this.
