Thread: who to send Red Trumpet Horns for rebuilding?
    I have an original set of red Bosch trumpet horns from my 71' that I need to get rebuilt. It currently makes a strange sound and definitely is in need for a proper rebuild. Any guys out there that specialize in these Bosch units that can rebuild them?
    Apr 2011
    N.Calif., south of SF
    Actually its pretty easy to do- go on eBay and find the all black trumpets. Order the long and short one. Once received, remove the electronics and transfer to your red ones after carefully cleaning polishing. Be carefully with the paper gaskets.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Oct 2010
    Southern Ca.
    I'm not used to seeing trumpets on a '71 . Do you believe them to be original to the car ?
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    My 71 has the red trumpets
    M.A.Spirito
    Aug 2011
    New York
    Shouldn't it have the red banjo horns? I thought the trumpet came in later in 1973.
    E Sully
    1973.5 911T
    Your correct mid to late 73
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
