Results 1 to 2 of 2
Thread: Distance break and clutch pedal to floor
    Hi,
    can someone measure the distance of a correctly adjusted break and clutch pedal in reference to floor? My 1965 Porsche 912 needs to have the break and clutch pedals adjusted and some measurements would be very helpful.
    Thank you in advance.
    Regards.
    Stefan
    The brake pedal is only adjustable as relates to the proper free play of the master cylinder pushrod, the clutch pedal is adjustable for whatever suits your personal taste. The accelerator pedal is also adjustable for height but must still hit the pedal stop at full throttle,,,otherwise you break stuff!
