Results 1 to 10 of 10
Thread: 901/30 spec ?
    Aug 2012
    France
    901/30 spec ?
    Just to check if my records are correct on 901/30 spec, please correct the below.
    The project is to make a 901/30 spec engine and put it in a MY1968 911 L.
    1991 cc aloy case (standard to the L)
    Single plug with yellow tag distributor
    Bosch W265 P21 sparkplugs
    L Crankcase and crankshaft
    L tie rods
    L rockers
    S spec camshafts
    S spec pistons
    N cylinder heads (normal small ports)
    Weber 40 IDS
    Black engine shroud
    Lightweight flightwheel (type ? Brand ?)
    Reinforced clutch (type/brand?)
    Cheers
    Xavier
    Last edited by Xavier PJB; 09-21-2014 at 01:27 AM. Reason: extracted information from the 2 threads listed below. From Paul Frere book too.
    O-G 26 - Early911S 2407
    There are no Ti rockers, probably adjustable steel rockers. I doubt it has Ti rods. The 901/02 Grupe 3 engines have 906 P & C's and cams, Alu cylinder air guides, adjustable steel rockers, tall manifolds and 46's. They do have Ti rods. single plug and big fan. Gled
    Aug 2012
    France
    For sure Geld these are 2 different engines - the 901/30 should get around 160hp and I believe the 901/02 more than 200hp.
    Maybe you want to check this thread ... http://www.early911sregistry.org/for...0-Racing-Rally
    Instagram
    Twitter
    Aug 2012
    France
    Quote Originally Posted by Biancaneve View Post
    Shame on me, Massimo I know almost this thread nearly by hearth, and did not refer to it . Thanks
    here is another link : http://www.early911sregistry.org/for...read.php?50203
    But please there are still some unknown/TBC.
    Cheers
    Aug 2012
    France
    update on #1, based on Sreg threads and Paul Frere book.
    Junior Member
    Jan 2019
    Hi,
    have you built this engine, 901/30?
    if yes, can you tell what it's like (fun, powerful etc.)
    Regards,
    Stef
    Aug 2012
    France
    Nearly, and car (with the engine) is sold
    Wow,,,really surprised you sold it after all that you've done to it!
    Aug 2012
    France
    Life is a bitch.
