Based on the thread, http://www.early911sregistry.org/for...040#post760040 , I'd like to understand what was my electrical problem (but my brain ) which drove me to too quick conclusion, however was really willing to help.
The engine is a 3.2 running PMO carbs, apart from the carbs the engine is 100%stock with DME still in place and partially plugged etc...
Was 400 kms from home, mid morning after a track session and a quick break at the track car park, the car was not fired up, no starter, but lights.
Tried several times, no starter.
I decided to ask one of the Porsche team's mecanic to give a hand to diagnose and fix. He tried to fire the engine up : no starter. Check the battery level, and was below 12v. Grabbed a extra battery and put in // with cables, and the engine fired up. Unplugged the cables and remove the extra battery - engine is running and got to iddle as regular.
Light on, 1500 rpm, the voltmeter indicated less than 12V. The mecanic diagnosed that the alternator was out of order. He told I could do track sessions but the electrical accessories would die as the batteyr level is going down until death of it.
I decided to get to the track, not stopping the engine of course. Did one 30 minutes session without any issues.
Out of the track I bought a new battery and a pair of cables, refueled too (I had to stop the engine). Restarted the engine with the pluging the new battery in // with the freshly new cables. It started instantly. Remove the cables and the battery. Went onto the highway and drove nearly 400 kms, but not using any electrical accessories, which was not really safe btw).
The day after, I strated the car with the same procedure, and check again the tension at the battery at 1500rpm - voltmeter shows the same as yesterday (less than 12volts)
Drove the car to my mecanic, did several things (which I do not know what) : same diagnosis - alternator is dead.
The alternator was changed by a brand new and it fixed the issue - the battery was still the same at the initial one - we did not changed it. After a short drive, all electrical accessories were up and the battery level was about 14V.
Did the procedure with idle at 1500 rpm, and the meter showed about 15 v.
So my conclusion was : you do not need a functioning alternator to avoid the engine running, but the electric accessories would not work.
Based on the thread at the begining of my post, It seems am wrong.
Then, I started to think (it happens sometines ) : the 3,2 engine as a regulator built in the alternator, would a faulfty regulator could have caused my issue but not keeping the engine to run off ?
I'd like to understand why, please enlight me.
Xavier
