Results 1 to 10 of 11
Thread: How to change light bulb in Blaupunkt Frankfurt radio?
    I've searched far and wide here and elsewhere, but haven't been able to find anything on how to do this. I found the obscure bulb the radio takes:
    https://www.bulbworks.com/light-bulbs/3370
    But nothing on how to change it. Anyone know the drill?
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Hi, you have to take off the chrome bezel, and the part behind that whith the glass. Then set the dial to (here is the problem I don't remember whether it's left or right) the most (left/right) position.
    Then you can take out the black part behind the scale (a small screwdriver will help) then you see the bulb - it is mounted at a slight angle and can be pulled out.
    If you can take the radio out of the car it's easier as you can take the top lid off and see what you're doing.
    Hth
    Uli
    Thanks Uli. Anyone else know how this goes?
    Aug 2009
    SF Bay Area
    There are just about as many different ways to change a light bulb in a Blaupunkt radio as there are different models. Take a picture of your radio and we can then suggest a way to do it.
    Jim
    Jan 2011
    Horb a.N. Germany
    Ok
    Turn the thing to the most left position
    Press a knob, only so far that all are released out position. (Not one of the AM/FM... is pressed)
    Remove chrome bezel
    Remove glass (open from top)
    Here is the point to lever with a small screwdriver (having the glass removed first)
    pull out on the right side (a lip of it is in a small slot on the left side)
    now move it to the right so that you can move it around the back of the needle (indicator? hand? don't know the english word)
    here you are
    Jan 2011
    Horb a.N. Germany
    If you haven't got it installed in your car you can remove the top cover and help getting the bulb out from the top.
    TRY THE NEW BULB FIRST BEFORE RE-ASSEMBLY
    Then Re-assemble in reverse order
    Thank you! Really appreciate it. This is the original radio to my car and has never been removed before, so I'm going to try to replace the bulb with the radio in.
    It's right there in the title of the thread, the Frankfurt model. Or maybe there different variants of that model?
    Jul 2011
    Chicago Area
    If your bulb looks like the one in the picture, then it is spring loaded so just push in and lift up reverse for install. Some also have a plastic white sleeve that the bulb sits in and the whole sleeve comes out (squeeze the sleeve together and pull out).
    Mike Fitton # 2071
    2018 911S Carrera White
    Dec 2003
    West Los Angeles
    Reviving this old thread
    I cannot find a 7 volt bulb with the bA7s form factor. Looks like the choice is a 12v or 6v.
    techweenie.com
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    have you looked in the store for children electric railway trains?
    just my 2cts
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
