Thread: Aluminum Anodizer
    Mar 2010
    Altadena, CA
    Aluminum Anodizer
    Is there a good source in So Cal for anodizing the window frames on a 911?
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    Call TRE or king of trim
    M.A.Spirito
    Anodizing is only part of the process. The surface finish of the base material must be meticulous (YMMV). Anodizing doesn't hide imperfections. It electro-chemically hardens and protects a thin layer of base material. I believe King of Trim does both (prep and anodizes) and charges a hefty sum (king's ransom?) for a perfect job.
