Results 1 to 7 of 7
Thread: Part questions
    May 2014
    Finland
    Part questions
    Hi!
    Two questions about some parts I have
    1. These transmission gears and parts came with some parts I bought from ex rallyracing garage, could be anything. Any idea where they fit? There is 4532 written with marker on both of gears. Clutch could be from same transmission but I haven found anything with the code. They used 3,8 NA engine back in the days, but not sure what kind of set up.
Size:  113.1 KBName:  photo 5(2).jpg
Size:  96.3 KBName:  photo 5(1).jpg
Size:  112.7 KBName:  photo 2(6).jpg
    2. Bilstein jack. What year was this model used?
    Mar 2006
    Louisville KY
    The gears are third gear out of 915 transmission. Six puck clutch disc hard to tell by the splines but possibly 915 also. You have a couple used bearing races and two syncro band snap rings looks like 1st gear and 2nd-5th. Oh and a jack.
    Tony Proasi
    52 split window coupe
    Feb 2012
    Edmonton
    The jack looks the same as what was in my '73 914 and 2 of my '73 911s. Not sure but I believe '73 was the first year for that style of jack.
    Aug 2009
    SF Bay Area
    It is a 911 jack, not a 914
    May 2014
    Finland
    Thank you guys! What a great forum!
    May 2014
    Finland
    Part questions continues!
    3. These seat belts came with one 1965 912, are they porsche-specific or just aftermarket?
Size:  88.1 KBName:  IMG_4084[1].jpg
Size:  171.3 KBName:  IMG_4087[1].jpg
    4. This map has been in my 1965 911 for at least 20 years and quite likely even longer. I have not before seen anything like it but just out of curiosity do you think it would be period correct? It has 15 pages that change by pulling the side "handless" and there is no need to open it.
Size:  131.9 KBName:  IMG_4097[1].jpg
    May 2014
    Finland
    5. Is this shifter knob was in my 1965 911, is it original or aftermarket? It is very similar to my other surely OEM all-black knob:
Size:  48.3 KBName:  photo 1(1).jpg
