Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: correct Air Filter Housing finish/paint-
    I really want to get the air filter housing Concours perfect. This is for a 1971 2.2 metal air filter housing. From what I've gathered and seen is that the original housing is somewhere in between a semi-gloss and glossy black. This same finish is also on the engine sheet metal tin and electrical box housing. What is your thoughts on the correct sort of paint?
    Also, did Porsche plate the raw metal of the air cleaner housing before applying paint? Unlike the paint on the body, the paint on the housing and other parts clearly never had a primer under the paint to make the paint stick the metal. So that leads to the next question- Did Porsche use a special sort of paint like an enamel paint? Did they oven bake the enamel paint so it would bond better?
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    They don't appear to have been plated in any way to the best of my knowledge.
    Satin black is what you want. Wurth is a good match, but I prefer 2pac or powder coat for longevity.
    Tony
    Nov 2006
    S. F. Bay Area
    I agree with powder coat, and a good-match industry standard color is BK-05, low-gloss black.
    Brian
    S Reg #1032
    May 2005
    Oroville, CA
    The original air filter parts were dipped as all of the engine tin was with a semi (satin) gloss enamel on bare metal then baked.
    Powder coat will last better but a little thick and sometimes losing some detail if not done sparingly.
    If you want them to look original, then the closest to dipping would be spraying them.
    IMHO
    H
    no they were plastic so don't paint them - find a good injection mold company and pay them $20K to design a mold and there you go
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Oct 2010
    Southern Ca.
    When you look at the engine picture in the '72 sales brochure , the black paint is shiny ; so why the satin ? The engine tin is shiny on my '73 E with 7000 miles . I don't mean shiny like the cars exterior paint , but cheap paint that was shiny and began to loose it's gloss the day it left the factory . I guess semi-gloss is close , but not satin- too flat . My 2 cents .
    May 2005
    Oroville, CA
    Quote Originally Posted by boxster03 View Post
    My 71 is metal and my 72 is plastic. Don't know the exact changeover but obviously I was talking about paint on the metal part....
    H
    May 2005
    Oroville, CA
    Quote Originally Posted by Richy View Post
    The black is easily influenced by cleaning or polishing...or flash photos.....
    The terms semi-gloss and satin are vague and used differently by paint mfgs.
    The main thing is the paint is not gloss. I have NOS engine tin parts that I match to and they are about 70-80% gloss.
    H
    Jul 2011
    Chicago Area
    Okay, now that the OP has his answer on the paint match, does anyone have any suggestions on reviving a plastic cover?
    Mike Fitton # 2071
    2018 911S Carrera White
Tags for this Thread
