I recently did a run of these for a guy in Japan and have these 3 test pieces left over. $75 each plus shipping. These are mechanical with zero preload and zero gas to leak out. Pull the hood up and it stays in place, pull the little knob to release and lower the hood. 2 have sand blasted finish, one with a delrin rod and the other with the lower mount plug welded. The third is all natural and can be left alone or finished with steel wool or scotch bright. These are for the front hood/boot.
