Thread: Door, Fender and Lid Gaps
    I seem to have misplaced my copy of the body measurements. Getting ready to set the rockers and quarters this weekend. I need to make sure that the gaps are supposed to be at 6mm. Right! Thanx in advance.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    saw a sceme for the correct gaps in a porsche repair manual i think it was 4,2mm +/- something......
    of course reale live is sometimes different...have had several untouched 911 in the shop and none of them had perfect gaps.
    Sep 2006
    San Francisco
    Just curious whether the gaps get adjusted for paint build-up. For example, gap to 5mm and then spray both edges to an expected net thickness of 1mm (.5mm per side).
    Jeff Jensen
    Apr 2011
    N.Calif., south of SF
    If I may add, and I don't know why, but the right side door gaps always seem to be slightly larger than the left. I spoke years ago to a factory production manager mentioning this and he confirmed that often this was the case until the 1974 cars, when the factory assembly jigs were changed.
    From car to car, I often will look and more times than not, the right side gaps are almost always slightly wider than the left .....
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by mobius911 View Post
    0,5mm on the door edges are way to much material (and not even easy to achive)
