Results 1 to 9 of 9
Thread: New REPRO 100L fuel tank / sending unit
    Sep 2009
    COPENHAGEN, DENMARK
    Made from scans of original tanks , so all small details are in place , and the bubble have the correct shape and placement :-)
    BUT due to safety, its not made as org in the back area!!! where the original top is only covers 3/4 and is spot welded to the lower back
    I have selected, to press the hole top in one piece , that way we could roll welded it all around , and its not a area you see once its in place
    it gives some minor wrinkles ( seen on org tanks also ) due to its a big piece of metal, that is stretched over a small area ,
    BUT for me safety comes first
    EACH is pressure tested, and have splash plates inside as org.
    the tank is priced at 2195 EURO
    New REPRO 100L Sending unit 195 EURO .....BUT only if you buy a tank
    Seperat the sending unit´s are 395 EURO
    options as Tire strap, skid plate , different center fill kits and more info / pics to follow asap
    For US Distribution / Sale contact Mike@Restoration-Design.com
    or email me at early911parts@gmail.com for more info
    Marek
    Sep 2009
    COPENHAGEN, DENMARK
    New REPRO 100L sending unit
    Sep 2009
    COPENHAGEN, DENMARK
    Thanks for all the respond
    A few asked, if the sending unit, is a old one just converted , the answer is NO
    Its Brand new manufactured from scratch ,
    Its also available in the normal size at 149€ ,To your info they are NLA from Porsche / VDO !!! surprise
    Marek
    Sep 2009
    UK
    Marek, still waiting for delivery of our breather pipes. 6 months now. Do these senders now have the VDO stamping.?
    Sep 2009
    COPENHAGEN, DENMARK
    hi Dave, breather pipe will be in the mail to you and Darren this week, it was offcause all a part, of the super deal you guys got :-)
    VDO stamping , No Way just blank
    Marek
    Nov 2003
    Santa Monica CA
    So what is the difference between this and Berts for $2800 ? chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Sep 2009
    COPENHAGEN, DENMARK
    Hi Chris
    Just to make it clear ,that the tank is NOT made by Bert, but by Mike Berg also a registry user from Sweden/Hungary
    I can point out a few things ,like placement and size of the bubble ,easy to spot if you compare the 2 tanks ,
    details around the sending unit , bulp around the air breather, and safety due to its pressed in one half
    Marek
    Sep 2009
    COPENHAGEN, DENMARK
    These Tanks are now on stock at Restoration Design
    Note that these babies, are made to exact measurements to originals
    and the halfs are pressed in one piece, for safety, not welded together, as some kind of patchwork
    I believe its the only 100L tank on the market ,thats made like that !
    ( pic shows, the inside of the top cover )
    Marek
    Marek please write me pricing in email for parts which we discussed over the phone
