Results 1 to 8 of 8
Thread: Adell clamp ribbon / rubber inserts
    Has anyone found a source or solution for worn out, cracked, torn Adell clamp ribbon / rubber insert, what ever it is called. The metal clamps are fine and when re-plated can be reused and for originality, need to be reused. Most of the clamps are 15mm wide so the channel needs to be that wide, or 5/8". Some are wider but if I could find just the one size I'd be happy. All vintage clamps had black rubber. The rubber pictured is SAE 1/2", the clamps are 15mm. Thanks Gordon
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    I would just buy new clamps and use the rubber portion on the plated ones.
    http://www.aircraftspruce.com/catalo...1919clamps.php
    Mark..
    Here's one choice http://www.nlaparts.com/store/licenc...mp-p-2303.html
    Or, Ebay type in CLAMP, LOOP CUSHION to get over 100 listings, some real cheap to get the rubber cushion.
    Oct 2008
    Burford, ON, Canada
    I went by my local Aircraft Spruce the other day, and have been meaning to drop in.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Hi Norma still manufactures these clamps.
    I will look more on eBay, the Yankee clamps at Aircraft Spruce come in different lengths but only 1/2" wide, just won't stretch over a 15mm wide clamp. I am looking at Norma clamps also. Gled
    Dec 2010
    Southold, NY
    Since seeing this thread I haven't been to town to check sizes, but I seem to remember that ACE Hardware has a fairly good selection of these clamps.
