Results 1 to 10 of 17
Thread: Turn signal lens gaskets
    The old turn signal lens gaskets on my Sept 70 Targa are in need of replacement. They appear to be grey.
    Aase has both black and grey at a good price.
    When was the change made from grey to black?
    Yours would have been grey. But you'll have a hard time finding an NOS set. I don't think Aase has them.
    Thanks for the reply. Aase has grey ones for the SWB cars and it appears to be the same size as the LWB lenses. I'll give it a try.
    International Merchantile sells the "correct" grey seals for the SWB & LWB cars. 800 356-0012
    Quote Originally Posted by TZombek View Post
    Ted, I'm pretty sure the profile is different, might need to verify.
    Nov 2006
    S. F. Bay Area
    I've long thought that the LWB lights/lenses were slightly bigger than SWB...
    Brian
    S Reg #1032
    Jan 2006
    Naperville, IL
    Looking on IM's site and their seal look black..?
    http://im356-911.com/product_info.ph...roducts_id=972
    Am I looking in the correct spot?
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Are grey turn signal lens gaskets for LWB cars currently being reproduced?
    I went thru this recently. Everything available when I checked was black.
    Jan 2006
    Naperville, IL
    I got a set from IM a few months back. I can provide a photo if needed.
    -Andrew
    '72 911E
    S Reg #1074
