I have been thinking about how to come up with the perfect early 911 driver which has no inherent value, so that you can just drive it, and don't have to worry about insurance and so forth.
I was thinking about buying a 2.2 liter 911T, and making a few tweaks to make it go, stop, and steer more like an S.
I realize that the aluminum S brakes will be hard to find and prohibitively expensive, but what about brakes from the 3.3 Turbo? Do they fit? Would they work without a servo? (I had a 78 911SC which had had the servo disabled by the PO, and it worked fine, but the turbo brakes are quite a bit larger). I am guessing at a minimum the hubs would have to be changed. I don't really like the brakes from later non-turbo cars as they are single-piston jobs which have a different feel. I think the Turbo brakes are much more in the spirit of the four-piston aluminum S calipers.
Steering shouldn't be too hard -- I think the torsion bars are the same; just the shocks and sway bars are different (IIRC). I always preferred, however, the semi-trailing arms from the later cars, which are sand-cast aluminum instead of rust-prone black painted steel. Does anyone know if they fit?
The big thing, I know, will be the engine, but I think I would really enjoy building one of these myself. I have a fantastic workshop at home which I've never really used since I built the house 14 years ago. If I'm not mistaken, the "T" motor has a different and inferior crankshaft, without full counterweighting, and simple cast iron, instead of the lovely forged and fully counterweighted crankshaft of the "S". I guess the "S" cranks are available somewhere, aren't they? And maybe I could use the RS jugs -- making 2.5 liters displacement, if I'm not mistaken. With the "S" cam, cylinder heads, and so forth. What do you guys think -- could I accumulate the parts to build such an engine for a reasonable amount of cash, say $20 -- $25k?
This is still a bit of a pipe dream so far, but if anyone feels like sharing some information or advice, I will be grateful!
