Results 1 to 10 of 14
Thread: Help,911 headlamp improvements,hid,singer type etc
    I have been using the search on here for the threads on the singer type hid headlamp conversions/improvements.
    Can any one direct me please
    I have H1 at the moment which are appalling for road driving,i would like to improve ,but hopefully maintain the correct look.i have 100 w bulbs in,which has not improved it that much.The reflectors are in reasonable condition.thanks
    Sep 2009
    UK
    Hi Paul,
    why not run a set of the powerful cibie biode lights.
    D-Zug makes them.
    Aug 2011
    Eugene, OR
    H1s should be pretty good lights, if the lenses and reflectors are in good shape. They also need to be aimed properly though, which is rarely the case in my experience.
    - Arne
    Thanks all for the replies
    The h1 are in good shape,and lots of time adjusting etc,still poor light even with 100 w bulbs.
    What are the cibie lights dave,i would like the lights to look fairly standard if poss,ie a clear unit behind the h4 or h1 glass.
    Who is d zug please.
    Senior Member Mrzoop's Avatar
    Aug 2012
    Piedmont Plateau NC, USA
    - Mark Z
    ESR #2450
    http://letter26.blogspot.com/
    Have you measured the voltage at the headlight plugs?
    Yes measured the voltage,one was down a little from a bad earth.
    To fit the 7 inch cibie type conversions,can it only be done in a swb light,or will the later h4 convert also.
    Aug 2011
    Eugene, OR
    The Cibié will fit either the SWB lights (under glass), or in sugar scoops (exposed). They won't go in H1 or H4 assemblies without considerable modification.
    - Arne
    The Cibie 7" are pretty much the same as an H4. Are you running relays? The light off an H4 with 80/100 bulbs is pretty awesome if all your wiring is up to snuff.
