Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: SVRA tires for early 2.0 911
    SVRA racing tires for early 2.0 911
    I will be returning my SWB 67S race car to a street car and building a 68L tub into my new racer. Seems like SVRA rules allow a 7 inch max wheel (front and rear), Anyone have a good tire and wheel recommendation? Looks like a 50 series tire is acceptable. I like that we may have a good consistent set of rules east and west.
    Erich
    Early 911S Registry #263
    Aug 2006
    Chicago area
    You should be able to run 7s and 8s, but will have to flare the rear. I believe the tires that are most popular are Toyo Proxes RA1s in 225/50 and 245/50. They 2 liters might be running 45 series tires - can't remember for sure.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Banned
    Nov 2004
    Scottsdale, AZ
    Actually...
    Most popular combination that is legal and that WORKS:
    205/50-15 on 7x15.
    225/50-15 on 8x15.
    RA-1's not available in 245/50. They do have 225/45 but be ready for a gearing change.
    Aug 2006
    Chicago area
    The master has spoken... I was going from memory and obviously wrong. Plus, I did not stay at a Holiday Inn Express last night.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Senior Member Vintage Racer's Avatar
    Sep 2007
    15 Year Member, Sandy Springs, GA
    Quote Originally Posted by ErichW View Post
    Looks like there are 2 classes.
    One is B-production and one is C-production. C/P is better if you have a budget.
    Doc
    1972 Porsche 911
    2023 Porsche 911 Turbo
    2019 Ford Mustang Shelby GT350
    Banned
    Nov 2004
    Scottsdale, AZ
    Erich,
    Regarding the two classes: Besides wheel size the most distinguishing feature is twin plug vs single plug and compression... and carbs.
    Sep 2007
    Frank,
    You forgot about weight.
    I believe the top five should be weighed. It can happen with or without the driver and safety gear. The current fast is to also lighten the top of the car and then add lead weight to the floor.
    Heck, you should make the rules. You know who is cheating and who isn't. You should tell Tony and his "staff" the real deal here. Tony is making millions of dollars (paddock rumor), and he can afford to pay you a lot of money to keep it fair.
    I am not kidding: I'd love to see you Chief of Tech.
    Doc
    1972 Porsche 911
    Banned
    Nov 2004
    Scottsdale, AZ
    Ha!
    Tony doesn't have enough money to pay me for that thankless job.
    I think some of the Porsche rules definitely need tweaking and they need to start pumping motors. If it's larger than the signed certification sheet entrant should be issued a 13/13 on the spot.
    I actually think cheating is rare out east.
    Erich, you need to decide where you want to fit into the food chain. If you build a competitive BP car you'll be running in top ten. CP? You'll have some great battles with the major appliances; otherwise known as B Sedan class.
    And don't forget to use a large fuel cell; at least 18 gal. The enduros are the best part.
    Thanks guys, I have been running my flat sided 67s for a dozen years, so it is time to go to 7 & 8's. Besides that I have been waiting 4 years plus for Brian P to finish my twin plug heads, so it is time to step up. The 68L tub is an 80's flare case, so nothing lost there.
    Stable rules east and west will bring the 2.0 racing back big time.
