Results 1 to 2 of 2
Thread: Getty Design Amber Fiberglass Shroud and RSR Surround Tins $675
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    I purchased these brand new form my 2.7. I have drilled holes and trimmed the pieces to fit. As you know these require a little "massaging". Once bolted up it looks pretty good, but there is some trimming that had to be done. The center piece that fits over the crankcase breather was generously cut, so I install a factory section in black underneath. The kit has maybe 25 miles on it and I've decided to go with something else. Once everything is bolted up it looks pretty good.
    SOLD. Thank you.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    Oct 2010
    Seattle, WA
    Shroud has been sold. Thank you.
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
