Results 1 to 8 of 8
Thread: Few opinions on what to put in cylinders of a 1968 longblock to keep it from seizing
    I am storing a 68' longblock that turns freely and it has duct tape over the top of the cylinders to keep junk out. I also covered it with a towel in the garage. But I have been told everything from WD-40, to regular mineral W30 motor oil. What is the best thing to do? I turn it with a socket wrench every couple months or should I do it more? It turns no problem. I want to pour more fluid in before I re-tape up but just want to make sure I'm doing the right thing. Thanks in advance for any advice.
    Aug 2011
    New York
    I use fogging oil in my cylinders. Commonly used for boat engine storage in the off season.
    E Sully
    1973.5 911T
    Never even heard of that, can you pick that up at a Marine supply store I presume? Why is it better than oil or WD-40?
    Aug 2009
    SF Bay Area
    The old standard is Marvel Mystery Oil. A 50/50 mixture of ATF and kerosene works well, too. Actually the best preservative is a nice dry, clean storage place.
    Jim
    WD-40 has zero corrosion prevention properties (I have a rusted 2,0 crank to show for that)
    When '065's motor was on the stand for FOUR YEARS (don't get me started) I used Corrosion X http://corrosionx.com/ it is awesome.
    Aug 2011
    New York
    Fogging oil is probably one of the best for cylinders. It clings and will not run off. Available at Marine Supply, or by me Sta-Bil fogging oil is in stock at Autozone.
    Marvel Mystery Oil, or 50/50 mixture of ATF and kerosene would work for freeing stuck rings, but I don't think it would cling to cylinder walls for long term storage
    E Sully
    1973.5 911T
    Aug 2009
    SF Bay Area
    Everyone should have a can of Corrosion X. That stuff is the BOMB! It says it is the "World's best Lubricant, Penetrant, Anti-seize. That is a fact!
    Dec 2010
    Southold, NY
    Corrosion-X works well in the salt water marine environment - will be perfect for you (good on firearms as well).
